So, Kermit belongs to Smedley, the hostess of Festiva Madness. Her one car Lucky has this upgrade that Karttacer installed. She wanted it on Green for Kermit, so I did it tonight.
Kermit looks blue in this pic for some reason, probably stupid phone.
Bought these lights at Advanced Auto ~15 bucks
Unlit.
Lit.
Used just one strip, comes with 3M backing tape.
Took off this screw...
Then this one.
Pulled that panel up, installed (glued) the strip in place.
Was able to sneak the wire through without any cutting or drilling.
Ran it like the stock wiring, stripped the wire back a little, loosened the stock screws a little, wrapped the wire around the screws, tightened them down, then insulated it all with hot glue (Handy.)
Installed the bezel back into the car, here it is dimmed all the way...
Which is how I have to use it to keep from being blinded, and here it is set to brightest.
Quick and easy mod, took about an hour, including shooting the breeze with Smedley, and watching a little of UNC kicking Pitts butt on the TV.
Unlit.
Lit.
Then this one.
