footrest
  • footrest
    I know that a footrest is intended for an automatic with cruise, but when I scavenged one out of an old AMC Eagle, it fit the Festiva floorpan perfectly.
    The question now is, do I want to weld on a pair of M6 weld studs?
    I only used four of them for my power lock install. Plenty left.
    Are you talking about a dead pedal?
    91GL BP/F3A with boost
      Yes, the one that's located to the left.
        Where do you put it?
        Picture of it installed?
          http://www.bernardembden.com/xjs/deadpedal/
          http://www.ursaminorvehicles.com/dead_pedal.htm
            It would sort of look like this in a Festiva (ignore the roll of paper towels).
              I was thinking of locating the footrest somewhere to the side.
                Seems like a good plan. Dead pedals are common on manual cars too. Your festiva has a manual choke?
                  Every 60s and up MTX car and truck I've ever owned or driven did not feature a dead pedal. The 5 speed Echo I drive now happens to have one and up until now I viewed it entirely as a Toyota gimmic. But I can certainly understand how something like this would be nice to have when you drive something screwy like an original 47 Ford P/U with high clutch and brake pedals coming up directly from underneath the floor.
