Has anyone done this? Is it physically possible? This would give us much better heat, and heat from the center dash ducts as well.
Aspire heater box swap into a Festiva?
Tags: None
Festy box is quite the convoluted contraption. I stared at the spare one I had for years. Seems to me if you can somehow fit a finer-finned or larger heat exchanger in there and increase the in/out coolant flow (larger hoses/ more efficient redirection of warm coolant from the engine) you might have something. Never got around to inspecting an Aspire box but did drive one (my first Aspire parts car) from Montreal to Ottawa during a January cold spell, enough to notice a significant difference in cabin heat.
This is a common concern, and the topic of many "new festy owner" help threads over the years.Originally posted by clphipps79 View PostI would like to know their reasoning behind not allowing heat to be had out of the front dash vents?Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Center Vent...If it was hooked up like other cars we would have to have a heater hose shut off valve. We would have to wait for the heater core to cool down to get the coldest air in the summer..air doors are not leak proof. If we have AC. same thing, it wouldn't work as good. Heater hose valves always leak a little hot water through the core even when off. Our systems are small and efficient as is, everything would have to get a little bigger and heavier to have all ducts work as one and work as well as it does now.
Some of you may recall that I put a big chevy heater core in my red car. When pulling snowmobiles it does put out way more heat. But all adjustments have been made to get the most efficiency out of the engine. Timing..emission controls etc. When the car is unloaded the heater really doesn't work that much better and the cooling system does not warm up enough to open the thermostat, in fact the injection is adding more fuel thinking the car is cold. Without the emission stuff to pull more fuel, the little b block does not make that much more heat to give.
In the summer the ac worked the same but the heater box cooks your throttle foot. In the oregon desert, endless sandy and dirt trails, gravel roads my honda rincon 650 id really fun to drive. BUT it gets worse MPG than the festy. These little engines when just loafing around like that do not make enough heat to put out like a bigger car or one with all emissions to spec. You have to burn fuel to make heat.Reflex paint by Langeman...Lifted...Tow Rig
Most likely some cost-cutting measure. These are low-end economy cars after all, and the heaters may have been designed more with warmer climates in mind. But I think saving money is the most likely reason.Originally posted by clphipps79 View PostI would like to know their reasoning behind not allowing heat to be had out of the front dash vents?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Specs from Rock Auto:
Festiva heater core dimensions...5.5" x 6.25" x 1.25"
Aspire heater core dimensions.....5.5" x 5.63" x 2.00"
The extra thickness of the Aspire core might be why it gives off better heat, with the same engine block. More heat transfer via longer fins. Same reason a dual-core Festy radiator cools better than a single-core. Yesterday it was about 10 degrees F, and I drove around in my Aspire perfectly comfortable; actually a little too warm, given that I was dressed for cold weather.
I'll bet an Aspire box could be put in there, using a combination of pieces; maybe the Aspire heater controls and a combination of Festy and Aspire tubing. Sounds like a good summer project for someone motivated to do this (Canadians, Minnesotans, etc.)
Alternatively, maybe the Aspire heater core could be put into the Festy box. Wouldn't help with dash heat, but might improve overall heating to floor and defrost.
Plus the usual solutions like covering all bumper and grill openings, and a partial bellypan, and even putting cardboard directly on the front of the radiator. And a 192 or 195 degree thermostat.Last edited by TominMO; 01-08-2015, 10:26 AM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Interesting that the exterior core dimensions are almost the same except for the 'head exchange' passages which are nearly double the length (2 inch vs 1 1/4). The longer a period of time that air passes over a set of heated pipes and fins the more warm that air picks up, you'd think.
Curious (boy do I like using RockAuto's site for comparing things) that most cars use 5/8 inch input/output tubing and hose for heaters. I happen to own an old F150 that blows real warm air so I looked at those core dimensions (7 x 7 1/4 x 2"); only to discover that 'cold climate' heater core dimension is same size as for 'standard' heater core but fin count/density and tube spacing is much higher. The Echo I'm driving (with lovely heater) has a 5 1/4 x 8 7/16 x 1 inch core. This is not radically different from that of a Festy (5 1/2 x 6 1/4 x 1 1/4") and yet heat output is significantly better.
Obviously there is more to this racket than meets the eye.
I think it is a insulation problem more than the heater core.
My heater blows pretty warm air but cant keep up with the drafts and just plan no insulation.
I lined the inside of the doors with this.
Repair, craft, label & decorate with Duck Tape Brand Duct Tape. Whether your next project is a simple craft or home repair, there’s a Duck Tape product…
And its a night and day difference! No joke its like if you were heating your house with the windows open before now it gets pretty dang warm although it could be better
Im going to be doing the doors and quarters on my other car.
Good tip. I clicked on Where to Buy and it came up with Wal-mart. So basically everywhere. Maybe big-box hardware stores too.Originally posted by william View PostI think it is a insulation problem more than the heater core.
Im going to be doing the doors and quarters on my other car.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Probably muffles that tin-can sound when you close the door too.Originally posted by william View PostYep got mine at Walmart. Its almost too thick comes close to the window. I just used spray adhesive it hold it90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
A little bit. To combat that you really need some sort of cld tile.
Like dynomat or something like it. Sound deadner show down .com has great information on sound deadeners and how to use each type. Before I was informed I thought that what I was doing was going to help sound and I got a shock at how much nicer the heat was.Last edited by william; 01-08-2015, 04:09 PM.
I think the type of material the heater core is, is also a factor.... copper vs steel.... just replaced the copper heater core in our truck with a different type of metal and it gives off ice cold air now, couldn't stay in the truck when the copper one was inLast edited by old yellow; 01-09-2015, 05:21 PM.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
