I use my headlights quite often, even in the daytime and I got tired of forgetting to turn my headlights off, so I installed a chime. I used a chime from Radio Shack. It's part #273-0071 and it was $10.99. They have buzzers that are cheaper and smaller, but I wanted a chime.
I ran the ground of the chime which is the blue and black wires, to the door switch. I used a ring terminal and use the screw on the switch instead of splicing into the existing wire. It took a little persuasion to get it back in the hole.
Due to a bad back, I didn't want to crawl under the dash, so I pulled the power for the chime from the back of the dimmer switch. I used the wire that is 12v when the lights are turned on. It is red with a gray stripe. I don't like Scotchlocks, so I cut off a little of the insulation, took a small sharp awl to create an eye in the wire and then inserted the red wire from the chime and wrapped it around a couple times. I soldered it and then used some liquid electrical tape.
I mounted the chime behind the left front speaker using a small cable tie to an existing hole.
Here's a quick crappy video of the sound of the chime. Unfortunately, the chime puts me in the mood for a 7-11 Big Bite with chili and cheese, but there isn't a 7-11 for 300+ miles from me.
