I have an extra tail light of both the early and late style I will be experimenting with as soon as I can find the time. I am hoping t find a way to separate it and remove the color I will keep everyone updated on my progress as soon as I find the time to begin
Red tails....searched, but no luck
Originally posted by PaulLehrI am hoping t find a way to separate it and remove the color I will keep everyone updated on my progress as soon as I find the time to begin
~Josh
Originally posted by xpnsyduv would seem to be the only way, but wouldn't that take like 5 years???
~Josh
[quote="packrat427
I thought you could use a special UV light that removed the color from the lens also .
Help PU241 :lol:[/quote]
John and I had talked about this some time ago ^^
I will rattle his chain on this one , he specializes in plastics , it's his job------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
quote="packrat427
Help PU241
IIRC the lens assembly is made out of acrylic and such is pretty resistant to UV, however the pigments used for coloration are sometimes less than UV and or thermally stable. If some one has a set out I can accelerate the UV exposure via a Xenon arc weatherometer, however this could also em-brittle the acrylic, as some one said this is an experiment. I also have access to a UV light source used in TLC with a specific output in the 290um range that does not have a heat cycle associated with it, as the weatherometer does. So we have some choices.
As for removing the lens has anyone used a 50 or 70% Isopropyl Alcohol water solution (standard solutions at wally mart) and only soak the portion of the lens you want out as it will also weaken the adhesive all around. Of course you could then do whatever you wanted with all the lenses and use another adhesive and glue them back good as new!'93 Blue 5spd 230K(down for clutch and overall maintanence)
Thank you John aka "Blue flight leader"
:notworthy: :notworthy:------------------------------------------------
Z28 LS1 power 500 +
i like my smoked black tail lights. I think it would look good if you made the turn signal red and the reverse light smoked
Ian Carr
88' flat black festy, has an e-brake that works!
99' S70 T5M- faster DD
86' 951- almost ready for track season
My old b6t- wish i still had it
http://www.cardomain.com/ride/2241793
Every car I have owned has had a turbo in it, until I bought this latest festiva.. I plan to fix that though.
how did you smoke the lights? and why didn't you do the whole lens?89 L, hopefully returning from the dead soon with a little more power... :twisted:
http://www.fordfestiva.com/forums/sh...77-my-89-build
Originally posted by fastivacaIf I remember correctly Fred used a Krylon product to paint the taillights with some kind of transparent finish.
The success of any painting project is the preparation.... clean, clean then clean some more.
* Retired Festiva-er*
1990 Festiva - The Once Fastest Red 1990 Festiva LX on this site! - now in more dedicated hands!
B6T'ing since May 2002...
Disclaimer: I'm a dick, deal with it.
spray paint does magic. I just used a thin layer of black plastic spray paint on my front turn signals, corner signals, and then the rear tail lights. I didnt do the whole thing because i like the black and red theme. Maybe after i paint my car black this winter ill smoke out the whole tail light.
-IanIan Carr
