OK, more weights.
The steel part of the front bumper weighs 20.6 lbs. The plastic cover weighs about 3.4 lbs. The foam weighs 2.6 lbs. The parking lights weigh about 2.4 lbs. Grand total of 29.0 lbs
If you are welling to give up all form of front end protection (as for a race car), you can just screw the cover and the parking light lenses in place to give the appearance of a "front bumper assembly" and have a weight of 5.8 lbs -- a savings of 23.2 lbs.
I haven't weighed a rear bumper yet, but it is probably the same weight or little more because of additional steel re-inforcing plates.
removing far rear weight like rear bumper and hatch would only be good if your doing straight line racing. The back end gets too light very fast. Unless you can do a bunch of suspension work to fix that somehow. Removing weight ahead of the gas tank and behind the front axil seems to work well
