I got this festy about a year ago and have only recently got it back on the road. The brakes were toast and I decided to replace them all around. As I worked through replacing the brakes (with tons of help from forum members!), I did a couple other projects to get the car ready for the road.
One of those projects was building a false floor so my dog McGee could ride in the back in comfort - as much comfort as a wolfhound / pointer can get in a festiva. My wife helped me out with this project. Neither of us had worked with carpet before, so we learned a few things but are very happy with the final result.
Step 1: We built a cardboard template of the back seat area. We just roughed out the shape of the sides by taping together different pieces of cardboard. We fine tuned the fit once we cut out the panels.
Step 2: We traced the template onto a 4' x 4' sheet of 1/4 inch plywood. You could use thinner material, but I wanted this to be sturdy enough for my dog.
Step 3: We cut out the shape with a jigsaw. We then cut this in half so it would be easier to get in and out of the car.
Step 4: We test fit the panels and did some more trimming, leaving some gaps on the sides so that the carpet would fit snug. We also left a gap between the two panels on the straight edge down the middle.
Step 5: We lay out the carpet and put the panels on top. We then cut out two pieces of the carpet in the general shape of each panel.
Step 6: Glue time! Sorry no pictures of this part, it happened fast!
We spread out one piece of the carpet and used spray on "trim adhesive" we picked up at Canadian Tire (or Home Depot?). We layed out the carpet and set up the panel we were about to work with. We coated both the carpet and the panel with the adhesive, very generously. We then carefully placed the panel sticky side down on the sticky carpet.
We then worked around the edges of the panel pulling the carpet over the back of the panel. This stuff dries very quickly so work quick. The trickest parts were the rounded edges because you have to cut the carpet when wrapping it to get it to lay smooth. The square edges were easier to fold around the back of the panel. Check out youtube to see how this done, easier to watch then to read. We didn't get it perfectly smooth but not bad for a first try.
Step 7: We stapled around the back side of the panels where the carpet was wrapped around.
Step 8: Insert and enjoy! We left just enough space between the panels and the two pieces fit snug. I was thinking I might have to secure the panels together but they don't lift up or move around at all. They look a different colour in the pictures but have since balanced out.
Here is McGee enjoying the new backseat.
Very happy with the way this turned out, I would definitely recommend doing this if you don't need the back seats.
