Finally got around to installing some small LED Light Bars in the hole where the Blinkers are supposed to go on my little brothers car. The lights we used were about $15 on Amazon so I'm sure there are some that are better quality but this was our first test.
As of right now have the LED's are wired into the Marker Light Circuit but will probably end up putting in a separate switch so that he doesn't blind everyone on the Highway. They are supposed to be "Spot" Lights but they still spread the light out over a large area. We also put some LED bulbs in the Marker light housing and wired in a 50 Ohm resistor and use those as the Blinkers now as well as some LED bulbs for the rear blinkers as well.
I am currently looking at some different lights for my car too so that I can try a couple different options.
