Weight reduction continues on RED, my non-street able BP drag racer.
I worked on the rear hatch today. Fiberglass was my first choice, but it was going to be a major pain and expense to make one. A member suggested reducing a door to just a "skin", so why not the rear hatch? So I went with totally gutting a standard steel hatch.
I can't find it in my notes but I believe that the hatch weighed about 45-lbs with glass in as well as everything else (hinges, hatch opening mechanism, brake light, etc).
Cutting just outside the seam area where the panels are joined, but leaving the seam for extra strength and helping to retain the shape, took about 6-hours of cutting with a cut off wheel, mini grinder, sanding disc and unbolting a few things.
The slightly re-enforced, partial "noodle" rear hatch - that does hold it's shape - now weighs 12-lbs without a window or mounting devices (hinges or such).
I plan on using a 3/32" plexiglass rear window glued and fastened in place, which is not only light but should greatly re-enforce the rear hatch from deforming (anti-noodle!)
I'll use a hood pin type mounting system and should be able to keep the total weigh at 14-lbs. This is a 31-lb weight reduction from the rear of the car.
Again, this is a non-street able drag racer - so this rear hatch isn't very appropriate for a street car.
If you are going to do this mod, MAKE SURE you wear full protective clothing - painter's head covering, full face shield, ear muffs, gloves and a long sleeve shirt!!!!
