At the moment, this will be the last of body weight reductions on RED, my Festiva BP drag racer.
As promised, to the front of the car!
Original steel hood and hinges -- 23.5-lbs
Lighten hood, no hinges (going to use pins) -- 14.6-lbs -- saves 8.9-lbs
This is one item that did not really lighten up much. There is a guy in the Philippines who makes a fiberglass hood - it may be lighter (???)
Original steel fuel tank - empty (no fuel pump, etc) -- 19.4-lbs locate in the rear of the car
Aluminum 1-gal fuel cell - has foam, no fuel pump -- 3.6-lbs locate in front right headlight area -- saves 15.8-lbs
I also got rid of the fuel tank filler hoses, filler pipes, filters, fuel lines and the entire fuel fill door-- Saved about 10-lbs.
Moving the fuel tank forward now puts the weight over the right front wheel for traction, instead of the original location over the rear suspension beam.
It will be a while before I get around to it, but I am going to greatly reduce the weight of the front hubs, brake rotor and brake caliper. Hoping to save 8-lbs of rotating mass per wheel for both weight savings and increased HP from reduced weight.
If you are ever in the New Bern, NC, 28560 area, drop me a note and stop on by!!! BBQ hamburgers await!
