I wanted to lower my steering wheel. I have a stock seat with a seat cushion so i sit higher. You can use the thick seat belt washers and b3 fuel rail bolts to do this. I didnt have the bolts and bought m8x1.25 by 2.5in long bolts.
Here is a quick video of it.
This is stock. Seat and camera are in the same position for the comparison photos.
![](https://uploads.tapatalk-cdn.com/20180225/acfaac57deed206eeaa3c1c27f097115.jpg)
![](https://uploads.tapatalk-cdn.com/20180225/b08a39724fe71e4ee152e10c4889a1f2.jpg)
![](https://uploads.tapatalk-cdn.com/20180225/84873fc44b1a62cc6573da6bc9cf2d1c.jpg)
With the long bolts the steering wheel was too low. It lowered the wheel 2 inches. I had to lift it up to get my legs underneath and the wheel blocks my view of the speedometer.
![](https://uploads.tapatalk-cdn.com/20180225/34d1a7f35c347b9e85f5b22f53282c66.jpg)
![](https://uploads.tapatalk-cdn.com/20180225/7f9a2b44e2d9e1df832cc2a5041864a9.jpg)
![](https://uploads.tapatalk-cdn.com/20180225/d21dd6bca554b3bcd8db7859eebdad8b.jpg)
![](https://uploads.tapatalk-cdn.com/20180225/139ac271b14c58f7e243fc40abb9da2c.jpg)
![](https://uploads.tapatalk-cdn.com/20180225/a6e5b982c82918a0255e4841fee02dd1.jpg)
All the nut and bolt stores were closed so i threaded my bolts more and cut them shorter. If you have to buy some youll want 1.5-2in long bolts
![](https://uploads.tapatalk-cdn.com/20180225/251bd51354a88907961f98f80b662c8c.jpg)
![](https://uploads.tapatalk-cdn.com/20180225/e7b19daf84eb2b22d35142bbd54fe71a.jpg)
![](https://uploads.tapatalk-cdn.com/20180225/5e046ba0d0db7b51d3b343392d470685.jpg)
I used 5/8in of spacers
![](https://uploads.tapatalk-cdn.com/20180225/484a5b8723b854259b09b15873c54995.jpg)
That lowered the steering wheel one inch which was perfect for me. Im about 5ft 11in tall. With the wheel a lot lower my leg hits the wheel when i go to hit the brake, but i think 1in is good.*
![](https://uploads.tapatalk-cdn.com/20180225/69633c25cbf108f8ad6281a47d6e9950.jpg)
![](https://uploads.tapatalk-cdn.com/20180225/04c32b1d59ad2197962d69b544d0942c.jpg)
![](https://uploads.tapatalk-cdn.com/20180225/4a1a9df6cbf37fa08fe30b7072be9270.jpg)
![](https://uploads.tapatalk-cdn.com/20180225/22850513f1d752e1db20e8eefd91ea84.jpg)
Ill try to remember to update this after a test drive. One thing i noticed is that you can see your spacers with all the covers back on. So pick ones you want to see....
Here is a side by side comparison.
![](https://uploads.tapatalk-cdn.com/20180225/a27eb45a45bb522eedb6b864bb644271.jpg)
