The Standins...
  • The Standins...
    From perusing various sites, including the old forums, I have made an assumption, but I want to make sure I'm right.
    Is it true that body kits intended for the 88-92 Honda Civic and the 00-03 Volkswagons will fit our cars the best, after being shortened?
    ya, I believe so because of the boxy style of both versions of those cars, they will need the least modification for our little beasts.
    I know the civic fiberglass kits are cheap enough to try it with and if you mess up your not out to much money :-) About 350 bucks...
      Has anyone considered the Scion Xb bodykits? They are certianly boxy enough. I'd also like to see pictures of any unfestiva-bodykitted Festivas, if they exist.
        Aw well, I've found some pictures of a CRX front mounted. It fits bretty good, I think.
        EVOGUN, do you plan on doing the CRX bumper in the rear as well? And how about skirts? I've seen the z24 skirts. Any others?
          Custom rear with diffuser.
          Thanks :wink:
