painting the aspire
  • painting the aspire
    i am going to get some paint tommorw i think, tell me wat u think
    Before pic
    after photoshop thanks sixstring, on fa.com
    2007 Ford Taurus 23-25MPG
    1976 Chevy Silverado (my toy)
    http://www.aintperfect.com/
    Fix that little dent in the quarter first!
    93 GL modyfied!!!
    :fish:
      Paint it the same color, so you don't have to do the underside of everything (hood, hatch, door jambs, etc., etc.).
        i am considering this but it will be pita to fix that one, cause of the crease right there, and i cant get to the inside of the metal to pound it out, (dad has a body hammer and dolly set so ive already looked lol) and the only other way i can think of is weld somthin to it to pull it out, like a bolt or somthin then get a piece of flat steel and brace it on the rest of the body, then put a nut on the bolt and tighten it down, but i rly dont want to weld more than i have to.
        and i have considered painting it the same color, but i just dont like the teal color lol, one reason i choose grey is because with tint, it looks slick, (ima get as dark as im allowed when i get the money for it.)
          and rly its not that bad, it just the light reflecting is wat makes the dent look bad.
            Metal is thin enough you have to be careful, but you can use the little slide
            hammer/dent puller that has a sheet metal like screw end,
            and thump it out.
            need to fill those little holes that need to be drilled in.
            More expensive is the body shop that has a gun that brazes little
            copper rivets to the low spots, and then use the puller, and the
            copper grinds off easy, no holes in the body
