ok first off,
i have this dent in the side of my car
its on the rear qtr panel if ya cant tell but i hope ya can lol
anyway im tryin to find away to pull it out, i cant get to it by pulling the trim on the inside off, already tried lol, dad was saying to take my torch and heat the area up with it, then take a chunk of dry ice and touch it to the heated area, but i dunno if it will work or not,
i was thinkin weld a bolt to the metal, get a piece of steel and brace it on 2 other spots on the body, drill a hole in the steel, then thread a nut onto the bolt, but again dunno how well that would work, i may have to punch a hole into it and use somthing to pull it out,
any other ideas???
also dad has a 80's model camero door with power locks, i was thinkin of attempting to rig a hatch popper with the acutator, you think it will work?
also i am going to make a hatch cargo cover for the aspire, first i need to trim the plywood floor bout an inch as my rear seat wont latch, but i have some cardboard im going to trim the layout and i have some 1/4" plywood in the shed i am going to use as well as the rest of the fabric i used on my hatch floor, but what i need to know, is how to make it pivot, and also what do i use and where do i hook it up make it lift up when i open the hatch,
Thanks in advance all
Charles
any other ideas???
Charles
