What is the best body filler out there? Is bondo ok, or is there better stuff? I was at a body shop and they had all sorts of different fillers from fiberglass, to stuff with metal or something in it
Good body filler
Re: Good body filler
Bondo had been improved from the heavy crap it used to be, butlook for a parts place that carries Evercoat, much better stuff.Originally posted by stefanWhat is the best body filler out there? Is bondo ok, or is there better stuff? I was at a body shop and they had all sorts of different fillers from fiberglass, to stuff with metal or something in it
but do your metal work first, using more than a 1/4" of any filler
should be avoided, use fiberglass instead if things are really
messed up.
Last, use icing or glaze putty for final work rather than lacquer
putty, as much as I used to use #M Acryl Blue, these do better
for even small pinholes
And no, I don't work for Evercoat, its just good stuff :lol:
^^ i second that go with evercoats lightweight body filler.....feathers nice doesn't shrink over time if used with a sealer of somesort. I would stay clear of ever 1/4"...more like 1/16 to an 1/8th IMO.---------------------------------------------------
and remember if you bondo over rust you're wasting your time. It will pop out in a short time.
