if you have seen the pics of the steel wheels on the 88' festy with 17k that i am buying, you notice they need some cleaning up. what would you use to clean and paint them? also wanted opinions on whether to keep it all original and just clean them up, or would you swap wheels, and if so what would be your choice.
has anyone ever thought of adding a higher bodyside moulding, ssay just below the crease. id always thought that would help with door and rear fender dings. as the other moulding is so low. whats your opinion on that?
