If you remove the metal bits that the back seat attaches to how much strength would the car lose and would it be roadworthy, also if i wanted to add more strength to it, would a bar (probably roll cage tubing) between the shock towers bne enough???
Weight Removal and Roadworthiness
I personally would not remove them , they are very similar to gussets , like on a tube chassis car , they do have some structural integrity to them .
The help keep the floor solid .------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
I cut mine out with a sawzall. It is definitely still roadworthy. If it does loose any structural integrity
its certainly not enough you will notice it while driving. A piece of tubing between the shock towers
would easily restore if not double the original rigidity, plus if your gutting the car those two
things sticking out just looks stupid. It looks so much cleaner with those gone.
check it out http://www.cardomain.com/ride/2433730/1Nothing says "triumph of enthusiasm over physics" like a Front Wheel Drive race car.
- Dennis Grant
FarNorthRacing.com
Remove anything that you're not using... I know that Wil complied a list of things to remove (he even used a USPS Scale to get an exact weight on the stuff he pulled out) - Common things, rear seat belts, seats, bolts, etc. Remove the spare tire, jack, interior panels, rear wiper and filler bottle.
Remove the passenger seat if possible/seat belt (depends on your situation really) - remove the front wipers, motor, filler bottle, etc.
At some point, you're going to need some of that stuff. I know that I need my wiper bottle because I drive my Festiva a lot... If you're going for a track only car, you can remove a lot more stuff without hassles - like headlights, corner lights, front and rear bumper supports, etc... I wouldn't do nearly as much in a car that'll see ANY road miles as I would for a track car.
And once you get the car light, you'll need to make sure that you still have traction when you're ready to run... Seems like that is the biggest problem of the Festiva owners.Simon - pimptiva.com
