Hello I am kind of new to festiva swapping and I was wondering if anyone has advise and/or pictures on the manual belt swap. I only have a set of manual belts... What is different with the headliner/pillar cover. I have read in many threads that there are differences but nobody says WHAT those differences are. Any advise or help will be appreciated. Thank you!
Automatic to Manual Belt swap
Soon to be BP'ed 92' white Festy from Worcester
http://www.cardomain.com/ride/2669252/1Tags: None
has anyone done this with out the trim pieces and headliner??Soon to be BP'ed 92' white Festy from Worcester
I have a set of manual belts in my car... It bolts in like the stock ones did. Unfortunately, I don't have any interior pieces (headliner, pillar covers, etc) yet... I'm searching for a mint 88-89 headliner that'll go in place and the covers for the A, B & C pillars.
You can do it without... And you can use the healiner from a 90+, there's just a gap from where the automatic seatbelt trim panel went that's not covered... It's not TOO ugly, but it's not that pretty either.
Just remove the trim panels, remove the bolts and retainers, unclip the wiring harness and the automatic belt will pull out. In fact, I still have a set in my basement from my first Festiva when I pulled them out... The manual belt has 2 holes it can be put in... I used the lower of the 2 because I'm shorter and it made the belt lay better on my shoulder. You'll have to make some sort of bracket for where the belt retracts into... I've seen just a small piece of metal hold it in... I think the PO of mine has it zip tied in... lol
I'm going for a set of harnesses once I get my cage/bar and seats.Simon - pimptiva.com
nice thanks for the info!Soon to be BP'ed 92' white Festy from Worcester
does anyone have any pictures of it?Soon to be BP'ed 92' white Festy from Worcester
can i see the pillar moldings and headliner?Soon to be BP'ed 92' white Festy from Worcester
when i brought a festiva back accross the border they said some cars can come into canada, and some can't, so i asked about it, i guess one of the reasons is because canada (at least Ontario) passed a law against having automatic seatbelts in ANY car
So whoever is looking to convert to manual belts, find a car in ontario, and chances are it has manual belts, i know i had never seen the automatic belts til the spring meet last year
^-- none of the festivas shipped to canada had auto seatbelts
here is a pic of the vinyl headliner
you can also see the b-pillar moldings on the left side
here it is installed along with a&b pillar moldings
89SX funtop! Fully loaded!
RIP 90LX
What holds the headliner in place that sits over the door?Soon to be BP'ed 92' white Festy from Worcester
It is pulled tight and glued underneath. The rubber moulding holds it also.Originally posted by audioxpert09What holds the headliner in place that sits over the door?
Here's a pic of mine. I did the swap but I had everythig from a parts car.
for the long stretches in the openings theres moulded plastic strips that clip onto the edge under the rubber gasket.Originally posted by audioxpert09What holds the headliner in place that sits over the door?89SX funtop! Fully loaded!
RIP 90LX
