aspire at trans brakes or m trans brakes..festiva swap...
  • aspire at trans brakes or m trans brakes..festiva swap...
    yo peeps....
    so iv been reading up on the aspire/festiva brake swap deal and iv been seeing that the aspire has 2 differant kind of front rotors.. ones for automatic aspires and ones for manuals..
    so when doing the swap to my festiva which is an automatic... am i going to have to buy the rotors made for the automatic aspire?
    am i going to have to find a automatic aspire donor car to put the brake system into a automatic festiva?
    NO it doesn't matter if the brakes come from an auto or manual aspire, both will work on the festiva,
    the aspire automatic rotors are thicker
    whichever one you get (auto or manual) you gotta stick with that, ie. auto rotors need calipers for an auto
    i have brakes from an auto aspire on my manual festiva
      oh ok so as long as the calipers match the rotors then.... cool.. i guess ima aim for an automatic donor so i can use beefy rotors thanks
        like i said though, if you start the swap using auto stuff, any parts you buy just remember to get all of them for auto and you'll be fine
          yeah will do.... thanks
            Try to find a auto to get the parts from. It makes it easy to remember what replacements to buy years from now.
            Just remember to get the rear axle from a two door car. The e brake line will be the right length.
