Yo peeps..
my entire shock and brake system is shot to hell so i fig it might be a good time to do the aspire swap. it will be one of the biggest task iv done to my fest so im pritty psyched out about it
based on my research the only parts i will be buying from the JY will be the parts i cant buy new like the torsion beam with the drum hubs, steering knuckle with hub and capilers.
everything else im going to buy brand new (pads, drums, shocks, springs, rotors and so on)
the only thing im not sure of is if im going to need the lower control arm, tie rod, sway bar or axles from the aspire or do i just use the festivas?
also the setup i have in mind is to use aspire shocks with festiva springs (not lowered) id like to have the car high but not be to stiff. this would be used for "cruising" and comfort. Does that sound like the right setup?
Poverty produces creativity
