Brake Fluid Article
  • Brake Fluid Article
    I found an article with some interesting info:
    From the article:
    This brings us to the imitations. There seem to be a rash of products available lately that claim to be pressure brake bleeders at a fraction of the cost of the professional units. Like most things that sound too good to be true, well, it’s exactly that.
    Like the professional units, these imitations contain a pressure vessel into which new brake fluid is poured. However, in order to pressurize the fluid, an integral pump handle is cycled to build the pressure inside the vessel without any measures taken to separate the pressurized air from the fluid. For those of you who have ever bought a $19.95 do-it-yourself potted plant and bug sprayer from Home Depot you get the idea.
    Of course, having pressurized air in contact with the brake fluid will certainly force the fluid through the system just as effectively as the high-zoot professional unit, but as an added bonus we are stuffing air into the brake fluid at the same time. Talk about an unwanted surprise!
    While it may not be visible to the naked eye (air can actually entrain itself in the fluid as to be visually undetectable) it’s there right along with all of the nasty moisture trapped inside of it. This of course begs the question: if you are stuffing air and water contaminated fluid into your brake system, why even bother bleeding it in the first place?
    Just thought I'd show this to get folks thinking. I know some people here may have gone the home made or el cheapo brake bleeder path.
    The rest of the article appears to be knowledgeable. I'm reading it because of my current brake episode. Gotta take better care of my brakes!
    Talk away!
    Speed Bleeder, Speedbleeder, SB1010, SB1010-SS, SB1010S, SB1010S-B, SB1010S-SS, SB10125, SB10125-SS, SB1015, SB1015-SS, SB8125LL, SB8125LL-SS, SB8125L, SB8125L-SS, SB8125, SB8125-SS, SB8100, SB8100-SS, SB7100, SB7100-SS, SB7100S, SB7100S-SS, SB6100, SB6100-SS, SB71624L, SB71624, SB71620, SB71620-SS, SB3824L, SB3824HD, SB3824HD-SS, SB3824, SB3824-SS, SB51624L, SB51624L-SS, SB51624, SB1428, SB1428-SS, brakes, bled, bleed, racing brake bleeder, automotive bleeder screw, bleeding motorcycle brakes, hydraulic, master cylinder, master cylinder bleeder kit, automobiles, car, cars, motorcycles, atv, 4wheeler, 4x4, dirt bike, screw, vent screw, bleed nipple, bleed valve, bleeding brakes, bleed brakes, bleeder thread pitch, trucks, screws, bleeder, wilwood, performace machine, stoptech, girling, brembo, ford, chevy, dodge, chrysler, pontiac, bmw, suzuki, mg, nissan, subaru, miata, RAM trucks, RAM, datsun, acura, fiat, gmc, chevrolet, buick, harley davidson, honda, kawasaki, yamaha, polaris, ducati, can-am, canam, triumph
    Just tried these and they work great.
    OX SMASH!!
      ^^ What size did you order??
      Ian
        According to their chart, the Aspire takes the part number SB8100.
        There is no listing for Festiva or Mazda 121 that I could find.
          Aspire swap, so SB8100.
          Looks like the raybestos part number for the festiva brake bleeder is the same as an 88 323. They list that as SB7100.
          OX SMASH!!
