Okay before you respond with "Use the search engine", I have and I have found mixed answers and holes in a lot of the info so I am making this post to get the exact answer.
So, here is my scenario and questions. First a little info about the car: it is a 1988 Festi with 230,000 miles that a friend gave to me because he didn't want to work on it. It is carbed and has a 4 speed tranny. I am using it for my daily driver and dog hauler (hence my user name). Like most of you I can't own a car with out modding it, so the new addiction begins. I have been combing the forums for weeks now looking for the best route to go with my Festiva and came to the conclusion that the best upgrade dollar for dollar to do first is the aspire brake upgrade. I bought all the aspire parts and a set of wheels and tires (this is where the problem is). After combing the forums I settled on a set of 15x6.5 wheels with a 38mm offset and 195/50-R15 tires because there were quite a few people saying they were running these and the only complaint was a little fender rub, which no problem b/c I plan to roll them. Here is where the issue and question come in. The other day I attempted to just put them up against the stock hubs to check where there might be clearance issues and to my horror they wouldn't sit flush with the hub by about 1/8-1/4" because they are hitting the spring perch. Now my question to those who are or have run this combo is do the Aspire hubs stick out further giving me the clearance I need? If you are running this wheel and tire set up, what brakes (Aspire or Festi), struts, and springs do you have on your car with this combo? I would really appreciate any help because I want to get my brakes on but don't want to start it if my wheels and tires won't fit because I will be without a car.
Thank you in advance!
Robert
Robert
