13 inch tires in 50 series
  • 13 inch tires in 50 series
    does anyone know where i can get some 13 inch tires in a 50 series other than tirerach.com
    i mean 165-50-13 is the size im talking about.does anyone know a place on the web i can find this size
      You can get them at Tirerack.com
      Kevin
        I checked Tirerack.com and found the Sumitomos in 175/50-13. Here are the other sizes for that tire:
        What's odd is there were no results for 175/60-13, which is perfect fitment for Festivas.
        The 175/50s are a bit "low," but some have used that size.
        I've never heard of 165/50s, unless that would be an original Mini application. If you do find this size, I'd worry that it would not support the load range safely. The 175/50s are already questionable in my mind.
        I knew the Falken Ziex in 175/60-13 was discontinued, but I figured the Sumitomos would do. Now it seems they may be hard to find as well!
        However, Sumis in 185/60-13 are still listed at Tire Rack.
        Karl
