Wheels and tires
  • Wheels and tires
    Hi, im new to the group and just got 88 festiva. i was wondering what wheel & tire sizes your guys are running on your festivas.
    14s with 195/45/14 tires, and 15s with 195/55/15 or 195/45/15 tires. Stock festiva bolt pattern is 4x114.3mm. There are lots of after market wheels that accomodate this pattern, but there is also the aspire swap which is 4x100mm(more common for after market wheels). You can look up the aspire info on your own.
    Kevin
      Welcome to the forum trb88 :!: You might look in the Custom suspension. brake, and wheel area if you haven't already.
        k ill have to check that out
          can you buy ay of theese at sears what brand and style choices are there
