My Festiva is a '91 5-speed on which I've already completed the rear axle part of the Aspire brake swap.
I'm wondering what I need to do to switch from Dot 3 to Dot 5(synthetic) brake fluid? I've been told this can become an ugly mess if not done correctly since the two types of fluid are not compatible.(I'm tired of corrosion from water in brake lines even though I try to change the fluid every year or so to slow this down)
Since I may be on a stringent budget, what if I want to use the front calipers I got out of the wrecking yard which seemed good, and also continue using the rear cylinders which are brand new?(and my current master cylinder; I'd likely hone and kit myself, if in reasonable condition to do so...)
I'm on fixed income from disability, so have plenty of time usually, but less money to use than even someone working full time on minimum wage.(including a section 8 housing subsidy-and I'm trying to relocate to San Bernardino in couple of weeks)
