Has anyone thought about or completed this mod??
I searched the board and coundn't find anyone talking about it.
I don't know much about fabrication and making pieces from other cars fit,
I'm just now starting to learn that stuff, but here's an idea I had.
I was looking at my moms intrepid and the way that the IRS is mounted on the car is a flat plate on the underside of the trunk that holds 2 (because I don't know what they are called I'm going to call them control arms, it's basically just a metal rod with 2 holes on either end) control arms to the brake Assembly and another that would go roughly where the trailing arm connect on are festivas.
If you cut out the spare tire depression and stiffen the deck with some thick enough steel, would this work?
Are there any other cars that anybody knows about that have the same kinda setup, in a smaller package?
josh
josh
