Hi guys im looking get new rims and tires for my festiva something more then the 12in that are on it im wondering what good rim with out alot of modification i can put on my 1991 festiva thanks all help is welcome
Rims and tire sizes that fit
14x6 is a really good fit for these cars with a 165/55/14 tire. Try to keep the offset between +10 and +30 for a decent fit with stock suspension. You can go up or down and inch in diameter pretty easily but 14" seems to be the sweet spot. I have found that searching for the bolt pattern (4x114.3) on Facebook Marketplace or Craigslist usually is the easiest way to find wheels."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
When running coil overs would +45 work? I found some e30 bbs wheels for 100 bucks where I live debating picking them upOriginally posted by firebush357 View Post14x6 is a really good fit for these cars with a 165/55/14 tire. Try to keep the offset between +10 and +30 for a decent fit with stock suspension. You can go up or down and inch in diameter pretty easily but 14" seems to be the sweet spot. I have found that searching for the bolt pattern (4x114.3) on Facebook Marketplace or Craigslist usually is the easiest way to find wheels.
The rear would probably rub but you can get a 5mm or 10mm spacer as long as you get longer wheel bolts or swap to wheel studs and lug nuts. I think the front would be okay but I can't say for sure."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
Swapping to the Advance Coilover Suspension in the rear would help out the ride a lot and only costs about $200. You can find the write-up for what parts and stuff in the Suspension section of the forum."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
I use geo metro or Hyundai accent wheels right out of the junk yard 13" and bolt on with zero modifications as long as you run 155 80 13s 175 70 13s require wheel spacers or swimming the rear spindles.30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.
Edge width and tire width are two firmly related sizes. Adaptable tire sidewalls alow a solitary tire size to be mounted on an edge of different widths. There is an edge width range for each tire size, however on the opposite side, there is a tire width range for each and every edge size.
