Power steering swap
  • Power steering swap
    Hey all, just bought a 92 and would like to swap out the manual steering and replace it with power steering. And know if it's possible with an older or newer unit. Thanks in advance.
    Hello! I don't think any Festiva had power steering? I could be wrong though. You could possibly look into an electric power steering aftermarket deal? Hope you find what you are looking for.
      P.S. was available but not too commonly optioned. You'd need the rack, pump, grooved pulley and coil for A/C compressor (if you want to keep AC), and maybe different crank pulley. If you stick to 145R12 tires properly inflated the manual steering is pretty easy.
        Thanks I will look more deeply
