Festiva Wheel & Strut Upgrade
  • Festiva Wheel & Strut Upgrade
    I'm wanting to change to 13" or 14" early Mustang wheels on my 89 Festy and have been digging through related threads for a while. Just a couple of quick questions to clarify my options. Seems that rear struts are getting much more difficult to source here approaching mid 2026. I'd like to change to Aspire rear struts but Rock Auto and all my local parts houses show no Aspire availability and it appears the available Festiva struts are in the $75-$85 range. My understanding is that the Aspire struts provide a little more clearance for the larger diameter tires (when changing from original 12" to 13" or 14"). Can someone tell me if the Festiva springs can be used with Aspire struts if I can locate some or do I need to acquire Aspire springs to use the Aspire Struts? Thanks in advance for any advice.
    If you use 165/65-13 or 165/55-14 tires (either are available on ebay) then you don't need to worry about clearance issues- they're the same width and diameter as the original tire size.
    '88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
      The Aspire rear struts are a popular swap on the Festiva because they share the same lower mount and spring perch design, so yes you can run Festiva springs on Aspire strut bodies - many people do exactly that without any fitment issues. If you're going to 13" wheels, the 165/65-13 tires keep the overall diameter almost identical to stock 155/70-12, so you won't need to worry about clearance at all and can skip the strut swap entirely if your current struts are still serviceable. 2 years ago I found mines at https://www.carid.com/ - check if they still have them (OEM Number is 341141 if Im not mistaken), because obviously Festiva is spply is declining. If not - ebay or as the last instance - go to your local mechanic - maybe they can order it for you through thier catalog, but will charge you for the install
