I don't know if they would work, but I have an easy idea how to find out. Take $125(notice the lower price) cash to the guys house, jack your Festy up, remove one wheel and put one of those rims on there. Things to note would be the location of the inner lip of the stock wheel, while on, to the location of the inner lip of the "new" wheel. If I were you, I'd remove a front and a rear wheel just to make sure every thing clears, ie, brakes. 5 minutes of work would answer your question, and if they work, you'd probably be the only one on here with a set like them. Pretty Cool Wheels!!
ENFORCER - Midwest Festiva Inc., Iowa
#2 .....Cheesehead
#3 '91 White - Donor Car
#4 .....Montana Project
SOLD----Levistiva for $1500
Bought her back for $450
Well the stock 12" steelies are 6" as well, so there's a 27mm difference between the stock and those. So they'd stick out another 2.7cm, which isn't a whole lot.
nope, stockers are 4", I had some 13x5s 35mm offset on mine for a while and they stuck out flush with the top (widest part) of the front fender... so those would be past 1/2" (wheel width/2) plus the 2.7cm which is a little over an inch. I'm not saying they won't fit, I would just recommend test fitting them buying.
