Sway bar bushings
  • Sway bar bushings
    I got the FMS anti-sway bar bushings, and they do not seem to match the clips that hold the sway bar on very well. When I tighten up the nuts that hold the clips (brackets) on they seem to squeeze the bushings too much. You can see them crush too much. It seems like a small spacer should be used on the bolt, under the clip, so that the bushing is not compressed quite so much. Has anyone ever tried this?
    Thricetiva replaced Icetiva as the new ride
    Icetiva-3-race-car-build
    i've never tried them but is it possible thats the what they're intended to do when installed? squish so it squeezes the sway bar better, just a thought
