Track width Festiva vs Aspire
  • Track width Festiva vs Aspire
    Is the track width the same? I know the LCA is longer on the Aspire but is it beacuse the frame rails are closer together. Are the CV axles on the Aspire also longer? The other Question is will the Aspire power steering rack fit in the Festiva? Thanx for the help
    The aspire does have a wider track width than the festiva. The festiva is based on the BF chassis while the aspire is based more on the BG chassis.
    Axle dimensions:
    festiva and aspire axles have an inboard spline count of 22 with an outboard spline count of 24. Lengths, for the festiva, are 23 7/8" and 34 5/8" left and right, respectively. Lengths, for the aspire, are 24 1/8" and 34 13/16" left and right, respectively.
    The Festiva Store
      So can you switch it out on the festiva so you get a wider track?
