Keeping it to the road
  • Keeping it to the road
    i plan on puting a B6t in a 1993 festivooohh and i wanna know what is the best way to stop spinning out. im new to this car building so i dont know much. does it only involve good tires and suspension?
    Well, There are several things. wider tires, upgrading the suspension, not dumping the clutch... Or, you can do what i'm doing. AWD. Instead of two drive wheels spinning, there'll be 4. Much faster take off.
    Of course the red makes it go faster..
      you have an all wheel drive festy?
      87 rx7
      92L starsky and hutchstiva bp swap, aspire swap, side pipes(tranny swap on the way)
      94 caddi deville
      99 f250 LD 4x4 12 inch lift on 38s
      i need more festies.
        bigchedd, stiffen the rear so that when you launch, there's less squat in the rear and therefore less weight transfer to the rear wheels. you can also rake the car nose down to help as well. biggest help will be tires and clutch control though.
