I have finally found a set of KYB AGX adjustables that will fit on the front of our cars.
When I say "FIT" I use it pretty loosely, this is my no means a bolt on part but for my
use it is perfect. After growing increasingly annoyed with the soft dampening of the
GR2 and tired of bottoming the shocks on every other bump something had to be done.
Enter once again our friend the 1997 Mitsubishi Mirage, KYB AGX part #'s 734011 and
734010 for the left and right side. The overall length with coilovers installed is about 1"
shorter than the festy unit and has about 3/4" more travel. Which means at 2" lowering
I still have the travel of the stock setup. No more bottoming and I get to run my LCAs
parallel with the ground. These struts also have some hardcore dampening ,the front
has never felt so planted. I will repeat this is not an easy job, I have access to a
machine shop which made the job alot simpler. It could be done with a grinder and drill
but would be a lot of hassle, but then again it is totally worth that hassle. You can get
them from Summit for 119.99 Each.
This is straight out of the box (a lot of work a do)
Using the mill to thin down this strut mounts on the hub (yeah, yeah, structurally
weakening critical suspension components is dangerous and stupid, also necessary)
Taking the spring perch off with a lathe (much prettier than just using a angle grinder)
Those are all the shots I took in the shop (I was tired and running short on time)
Mounted and installed (sideways yes I know)
Look closely and you can see an extra mounting hole by the bottom bolt (they were
spaced too far apart so a new one had to be drilled (another place the mill came in
handy
New 7" 250lb springs
4 position adjuster on top of piston rod (not a very clear pic)
Another side shot
Front shot all bolted up and ready to roll
New Lower Floor brace helps reduce chassis flex (it really does too)
Rear strut tower brace (its never felt so stiff back there)
Hope you enjoy the pics, any questions my door is open. - Chris
handy
Another side shot
