mirage rims
  • mirage rims
    was wondering if a set of rims off a mitsubishi mirage would fit on the festiva with no problem. they are the same bolt pattern because i have the aspire brake swap done. i think the tires on them are 185/65/14 but not for sure. i will be going to look at them tomorro and test fit them but thought i would see if anyone has put them on before. thanks
    Daily Driver: 90 Festiva 5 spd. lime green, brush guard
    Another Toy: 06 Harley Sportster 883, intake and exhaust
    Mirages are all 4x100 as long as they're >1993. Any 1993-2002 should be fine.
    1988 Chevy Sprint Turbo 997cc
      ok. i was wondering on the backspacing and everything though. if they would rub and hit or anything
        i ended up buying the rims. they have 195/60/14 on them with less than 5000 miles. nice tires. they will fit. a little tight in the rear around the spring perch but i will get that figured out. now i will have to get a set of wheel studs though or longer lug bolts cause mine are not long enough. ended up giving a 100 for all 4 with the tires so im not complaining
          Good deal,you should be able to get wheel studs at any tire store.
          99 Dodge Caravan SE
          95 Taurus SHO auto 265hp
          94 F150 351W auto (for sale)
          95 Honda 1500 Goldwing SE
          95 Iszuzu Trooper LS
            How's the centerbore fit? Is it exact?
              not sure if its exact but im thinking it is pretty close. i will have to check again once i get them installed and let you know
                Mirage rims don't work i bought some a wile back i couldn't let the car down cause it hit the shock. also if you have the aspire swap it won't bolt on cause i don't have the aspire swap and it bilted on but the bore in the rim was a lil bigger...
                1989
                Ford Festiva L
                Automatic
