bigger brakes
  • bigger brakes
    i just got some 14in wheels, and was wondering if anyone knew if there are some bigger rotors and calipers that fit into the stock festy bolt pattern.
    87 rx7
    92L starsky and hutchstiva bp swap, aspire swap, side pipes(tranny swap on the way)
    94 caddi deville
    99 f250 LD 4x4 12 inch lift on 38s
    i need more festies.
    None. At least none that are direct bolt in, that are with the 4.5 bolt pattern.
    - Unknown
    - Quentin Crisp
    - Bumper Sticker
      ok how about any suggestions
      87 rx7
      94 caddi deville
        how about rotors from an accord? thats where the wheels came from.
        87 rx7
        94 caddi deville
          Gonna need input from someone whos done something other than the Aspire swap. I know theres another one that can be done. But that also meant the more common bolt pattern shared by Aspires ,Escorts Etc.
          Nothing though that maintianed the 4 X 4.5 bolt pattern that Festivas have. And Im sure that has to do with it not being a bolt in swap.
          - Unknown
          - Quentin Crisp
          - Bumper Sticker
            look up FestYboy. He did a Capri swap. Bigger rotors and calipers up front, Festy bolt pattern.
            Jim DeAngelis
              i got 323 gt front rotors on my KIA pride since 2004, itīs almost a bolt on
              youīll need some 14" wheels becouse the calipers are bigger obviously
              bye!
                does the 323 have the same bolt pattern?
                87 rx7
                94 caddi deville
                  this one was a 86 323 gt or GT-x (iīm not sure) sedan 4x114.3 same as the Kia pride
                  bye!
                    thank you
                    87 rx7
                    94 caddi deville
                      hmmmmm....well then what about a regular 323? Would they bolt in and would they be bigger?
                        i donīt know :S but my rotors are very similar with protege 98 rotors same diameter, but the bolt pattern itīs 4x100 the calipers almost the same
                        pics (my rotors)
                        i think regular 323 or familias are 4x100
                          Yeah the 18v caliper is the same as the one on our BG protege's, & escorts. Some one on here swapped the EGT caliper onto something recently...
                            the egt caliper fits on the aspire spindles, i stuck them on my festiva, they work good.
                            Mike, AKA the sasquatch
                              the capri calipers/knuckles bolt right in with the use of aspire control arms. You MUST use the aspire LCAs, festy arms are too short. you'll still have the stock bolt patern, just now with larger, vented rotors!!
