Finally got my front-end converted over to Aspire stuff and also brought home some 13" wheels I found laying around the junkyard Aspire. (175/70/13)
Previously I was running 13x6 Aero race wheels with Sumitomo HTR-200s. (185/60/13) Great combo and no reduction of power compared to stock wheels and tires. Only problem was vibration due to the Aero wheels not being hub-centric.
Now that I have the junkyard wheels which look quite a bit bigger than the sumitomos I'm having trouble getting up hills in 5th which never happened before. I'm still at work so haven't had a chance to compare weight but does anyone know what the stock aspire steel wheels weigh? are they unusually heavy?
I was hoping I could get away with using stock steelies w/ hi performance tires but now i'm not so sure. I dont understand why they would be so much different than the Aero/Sumitomo combo. is it the tires or the wheels? something must be heavier causing my power problems. Or could it be gearing due to increased tire diameter?
open to any suggestions or thoughts. I'm on the lookout for some stock CRX wheels. I thought I read these were 7lbs?
thanks,
dan
thanks,
dan
