Anyone ever see chrome lug bolts for a festiva or can you install studs and get chrome lug nuts ?
Chrome lug bolts/nuts
Celebrating 25 years of festiva(s) ownership.Tags: None
i have studs that i got from a custom wheel shop, i also got chrome lug nuts with them. they are on my starsky and hutchstiva(only the back). they cost $1.50 a peice for everything so about $50 for a full set.87 rx7
92L starsky and hutchstiva bp swap, aspire swap, side pipes(tranny swap on the way)
94 caddi deville
99 f250 LD 4x4 12 inch lift on 38s
i need more festies.
the studs i belive are 12x1.50. any custom wheel shop should be able to get them. mine only took a day to get in.
as for lug nuts, auto zone usually has all diff. colors and you can get locking ones if you want.87 rx7
94 caddi deville
Cool, Id love to have a couple of sets of those chrome lug bolts. The bolts in the gorilla listing are all too long, my festiva lug bolts measures 1 5/8" long. Just buying the bolts is probably cheaper than buying the studs and the nuts.sigpic
I have also been hunting for these
Check out this site. http://www.karmannghia.com/viewDetai...idProduct=8025
I found another site with chrome bolts too, but can't locate the link right now. I'll post it when/if I do though, because I think it was cheaper.
Nice, thank you !! Ill have to go the hardware store and get specifics on the threads of the stock bolt. Its a must have now that I know its possible.sigpic
Hey Fresh
Here's that other link
http://www.jbugs.com/store/merchant....gory_Code=1279
If you scroll down the page, they have a set of 4 chrome lug bolts for 9.95. Hopefully the thread pattern is right.
On that note, I have a question about something they have on that page. The 5 lug wheel to 4 lug hub adaptors: is something like that an option with festivas?
Thanks!
Laura Z
'90 Festiva LX (Moe)
65k original miles!
Well I dug around in the vast, but interesting, great unknown waste land I call a garage and found some lug nuts with the same thread as the stock festiva lug bolts. Im going shopping the next chance I get. The spider web is unrelated, I just thought it was well built.
well the reason for longer studs is if you have to do some spacing, which is why i had to get them87 rx7
94 caddi deville
