stock lug bolt size
  • stock lug bolt size
    I know it is a 14mm socket, but what are the specs?
    can you get longer bolts?
    -Aspire brake swap COMPLETE!
    Discuss improvements to your Festiva or Aspire in the handling, braking, wheels and tires areas.
    here you go
    87 rx7
    92L starsky and hutchstiva bp swap, aspire swap, side pipes(tranny swap on the way)
    94 caddi deville
    99 f250 LD 4x4 12 inch lift on 38s
    i need more festies.
      thanks, i couldn't find that when i searched...
        yeah, the search button can be hard to find exactly what you are lookin for.
        87 rx7
        94 caddi deville
