Just bought a set of wheels and was wondering what you guys do for wheel bolts mine are kinda rusted and I dont want to put them on these wheels.
i have a set.well ill have to check to see if there all there first,but i will sell them if interested,or you can freshn up yours with a lil sos sandpaper,primer,and a lil paint.
forget the bolts. get a set of studs and lugnuts from summit. really easy to install and makes wheel removal and more important replacement a breeze. I have them on both of my cars and would instantly get them for the third.
wcbarker,
Go to the bottom of the page on the following link. 2nd from the left is what I used along with chrome lug nuts. You should be able to get them from any place that sells wheels and tires. Hope this helps.
kinda had the same question... so monsoon... if i would go to my place of work (Checker Auto) and get 16 studs and 16 lugs, I could just put them into the hub assembly and it would work, rather than buying a whole new hub???
Those look nice Fresh!
Are those 17mm heads?
I got some in the mail a little while ago!
