Hey, I just got my parts for the Aspire swap, and even though I ask no to cut the handbrake cable, the guy did... I've called NAPA, and they don't sell those; they tried every parts furnisher they knew, but no luck, and I'm pretty sure my Ford dealer will tell me it's discontinued. Can't find it on Rockauto.com either. I need the cable that goes from the handbrake handle to the cables on the beam. Won't the Festiva's fit???
Aspire swap-Parking brake cable
Festiva's works fine... who told you otherwise?
the cable from the aspire 2dr, 4dr, and festiva are all the same.~Nate
Current cars:
FOTY 2008 winner!
Actually... I'm pretty sure that the Festiva cable is too short and requires SOME sort of extension. At least, that's what I've always heard.
I'd shoot for the junkyard. I need to get a new one for myself the next time I go out (maybe this weekend!), as the one I have now only pulls the passenger side brake... :-PSimon - pimptiva.com
thats interesting... when I did my swap I thought i lined them up and they were exactly the same, any info on what part is shorter? the part from the brake handle to the beam, or the pieces after the "Y"?~Nate
Current cars:
FOTY 2008 winner!
Well, from what I understood in the how-to on this site, you need the Aspire's e-brake cables. Anyways, here's a pic to show you which cable is cut on my beam and where:Originally posted by skeeters_keeper View PostFestiva's works fine... who told you otherwise?
The ones going to each drum are intact though. So, is it a go or no-go with the Festy's main cable?The left lane? Are you crazy!!! I never drive in the left lane...It's full of freaks driving the wrong way and charging right at you!!!
when i did my swap i put on all new brake shoes and when i tried to use the festiva cable, the part that goes to the drums is too short, so i had to use the aspire cable, to me it makes sense that if your using the aspire brakes you should use the aspire cable
the festiva cable works. i just hooked my festiva cable back up (after yanking it out only to realize that the aspire cable that i got w/ my rear beam was broken in a place that prohibited it from being used) and it seems to be fine. if something doesnt reach, etc...people may want to make sure that the tension is adjusted at the middle of the beam or even at the front up where it attaches to the e-brake handle.
UPDATE:
im actually going to amend the above to say that the cable MAY work. its on but so is the light that says my e-brake is on. the cable fits but the adjustment screw/bolt at the handle only allows you to tighten the cable as your pads wear.
is the only place where you can give it slack at the middle on the rear beam? or is there somewhere else that im missing? it may be moved further towards one wheel or the other on each car. honestly, this rear set-up is a very poor design in my opinion... the one and only difference between the festy and aspire cable may be this mounting point. it may work if your brakes are worn down enough but not with new pads. im going to stay on this and keep everyone updated as i sort this out.
in regards to the center mounting tabs distance from each wheel, does anyone have a festy and aspire axle that they can compare?
UPDATE #2
was at the yard and picked up an aspire cable. layed it on the ground side by side w/ the festy one. the driver side cable appeared to be about 1/2" longer on the aspire vs the festiva. the other side (when pulled tight) appeared to be the same length. they are so close in length that im not sure what to say. my e-brake light is still on so that must have to do with something else/the rear brakes needing to be adjusting or something...or a faulty switch since there are no sensors in the drums or anything like that.
