does a front sway bar from an aspire use the same mounting brackets as a festiva?????
sway bar question
check with Nate (Skeeters Keeper), but i believe they do with new bushings.Trees aren't kind to me...
Repair or custom suspension forum question ?sigpic
You need the aspire mounting bracket that houses the bushings, and you obviously need the aspire bushings.
However you use the festiva bracket that bolts to the frame/core support via the three bolts.~Nate
Current cars:
FOTY 2008 winner!
