the aspire lines obviously mate fine to the aspire rear hard lines and work well with the point where the retaining clips hold the soft lines. however, im having trouble with where the soft lines hook up to the hard lines on the body/festiva side.
the metal end of the brake line is a different size than the festiva and if you put it into the metal part where the retaining clip goes and try and tighten the flare nut, the soft line just ends up spinning.
what have you guys done to solve this problem? just use vice grips to hold the soft line? -- id rather not do this if i didnt have to. or can the tabs be bent in? -- i was attempting this but they seem really sturdy and i didnt want to mess anything up before getting some feedback. or is there another option im missing?
thanks.
thanks.
ccasion5:
