help
  • help
    i cant get my aspire sway bar to fit my festiva.
    the problem is it seems like it wont go back far enough to go into the groove where the mounting plates go.
    any ideas would help.
    87 rx7
    92L starsky and hutchstiva bp swap, aspire swap, side pipes(tranny swap on the way)
    94 caddi deville
    99 f250 LD 4x4 12 inch lift on 38s
    i need more festies.
    I've never done this, but are you using the Aspire mounting blocks? I think you're supposed to use those instead of the Festiva's rubber blocks.
    Karl
      It's hitting the round part of the front transmission mount. I took a power hacksaw and cut part of the mount (both metal and rubber) off until it looked like a fat letter "D". Then I welded a piece of 1/8" steel across the end of the cut to keep the mount stable. Weld a little bit at a time so you don't burn the rubber.
      You gonna race that thing?
        ok so.... who wants to take a trip to destin, fl and weld something for me?
        87 rx7
        94 caddi deville
          any pics to show what your trying to describe?
            no, but the round tranny mount on top of the tranny crossmember hits the sway bar... if that clears it up at all
            87 rx7
            94 caddi deville
              Mine hits in the same place you'll be fine.
              Renegade-Midwest Festiva Inc.Illinois Chapter
              99 Dodge Caravan SE
              95 Taurus SHO auto 265hp
              94 F150 351W auto (for sale)
              95 Honda 1500 Goldwing SE
              95 Iszuzu Trooper LS
                i cant get it to go all the way back. i cant get the two mounting plates lined up.
                87 rx7
                94 caddi deville
                  I did the same thing...I didnt like it hitting the mount sooooo I redrilled the mounting holes for the mount that bolts down to the cross member and than I moved the tranny mounting location also. Basically you have to redrill 3 holes for this to work. Now I have great clearance and everything is in stock location. Whatever you do, DO NOT modify the rubber! This will change the geometry of the suspension and you will be driving sideways. The brackets for the swaybar from Aspire and Festi are the same, the only pieces that are different are the bushings, which have larger openning to accomodate the larger swaybar.
                  If anyone is interested I might crawl underneather and take couple pics? Just let me know
                  Ski
                  1986 Ferrari Testarossa
                  2002 BMW 745i
                  2002 BMW 325i
                  1989 BP'd Festi :p
                    pics would be awsome.
                    87 rx7
                    94 caddi deville
                      Look at the space between the bar and the round tranny mount! Not much but its not rubbing either!
                      I hope this helps....
                      Let me know
                      Ski
                      2002 BMW 745i
                      2002 BMW 325i
                      1989 BP'd Festi :p
                        so you basically moved the mount holes on the cross member and the whole that the tranny mounts to the mount correct?
                        87 rx7
                        94 caddi deville
                          Simple huh? But thats it! Anyways, I hope this helped? Also, fix that rubber bushing/bracket while you're at it please....
                          Ski
                          2002 BMW 745i
                          2002 BMW 325i
                          1989 BP'd Festi :p
