Plz help!
  • Plz help!
    Hey guys, this is one of the most asked question on this forum, but try to help me out!
    i know 185/60/14 fits with spacers But i am having a real hard time finding this size...
    Would 185/65/14 create more or less problems... it it just woundn't fit?
    Thanks in advance and i hope monsoon doesn't strike
    The 185/65/14 will be taller and hit more.
    93 GL modyfied!!!
    :fish:
      not to mention the speedo differance....the 185/60's make a differance of about 3 mph's...speedo reads slower, so the 65's would make that a bigger differance.
      I have coil spring spacers on the front of the car, do not have the rears mounted yet, and I have had no issues whatsoever with the hitting issues I had before the coil spacers.
        the offset of your rims makes a big differance. i'm running 185/60s with a +35 offset and rolled fenders. no problems there! i would recomend using aspire rear struts to give the rear tires a little more room (they rub the festiva strut perches in hard corners). if your rims are a +40 offset (or more), you NEED the aspire rear struts to provide clearance, otherwise the rear tires won't fit or you'll have to use large (unsafe) spacers.
