would a 40 offset work?
offset
offset
Frankie
fully custom 88 festy (project doomsday) Febuary in 2012 calander
Blockspire: ken block replica aspire
AdvancedDynamix: "If you put the same kind of effort into your engine that you put into the rest of the car, well... it'll be epic". thanks man
http://www.facebook.com/#!/profile.p...00000110128487Tags: None
It will. There is a lot of good information in the Custom Wheels/Brakes set up section (or use search) about tires, wheels, offset, bolt patterns, etc, etc, etc. There are sticky's there and a lot of good threads to learn from. Check those out and you'll find more than you can ask aboutOriginally posted by frankm201@yahoo.com View Postwould a 40 offset work?
'93 Festiva GL / "HOT ROD"
'02 F-150 Supercrew
'02 Excursion 4x4
'98 Jeep Cherokee Classic Limited
depends on the width of the wheel. 40 will work if it's a 6" or smaller width, but that;s it.Trees aren't kind to me...
thanks yallFrankie
