Anyone put an Aspire sway bar in a BP Festiva? I assume it would be same as in a 1.3 but I was just wondering.
It will fit,engine size don't matter!Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
"some" is an understatement... making it fit with the BP + G25 is a lot harder than with the B3/B6/BP and festiva trans (its not the motor that makes the difference, its the trans).
If you're using the festiva trans, no problems (although I and several others have modified our front trany mounts anyway to make it fit a little better), if your using the G25... its a little more difficult. We have the mount made for the G25 with the aspire swaybar, but since the swap isn't running yet we can't report on just how well it worked, but it should be OK. to give you an idea: we used a rear EGT trans mount, cut and drilled the Xmember, bent, twisted, then welded two pieces of 1"x1/4" steel, and added a 6" long bolt with spacers, and have < 1/8" of clearance in about 4 places (hence the solid ploly mount Paul mentioned). If you have a cable clutch G series trans it'll be a little easier, but still harder than the festiva trans.~Nate
Current cars:
FOTY 2008 winner!
do all aspires have sway bars?Last edited by ejp2fast; 01-27-2009, 04:30 PM.
-Aspire brake swap COMPLETE!
^^ what!?!?! ummm wow
i'll walk away from thatTrees aren't kind to me...
Originally posted by oxbrain View PostI can't see how stiffening the front sway bar would do anything but hurt cornering ability.Jim DeAngelis
Originally posted by FB71 View Postyou got it bass-akwards... stiffer swaybar = better cornering
You might feel quicker turn-in, which would definitely make the car feel faster.OX SMASH!!
BOOYA oxbrain nailed it! Personally I wouldn't do it. The Festiva tends to understeer even moreso than most FWD's and putting a stiffer front bar I personally think would only make it worse. Alot of FWD AutoX cars do NOT run a front bar at all... Just some food for thought. -KyleCosmic Blue 2008 Mazdaspeed 3 - Mostly Stock...
White 1990 Ford Festiva - B6 SOHC powered 50 shot = 14.5 @ 94 mph Gone but not forgotten
Proud member of Chicken Mechanix Racing
