wheels
  • wheels
    hi, i have a 93 festiva wa and i am just wondering if the newer festiva wheels fit the older style cars?? and also what is the widest wheel you can put on the 93's without it rubbing or causing any damage??
    I have a set of 15x6 wheels from a Sonata. Put 3/16" spacers on the rear to work. Mine is a 93GL.
    Chuck
    91 GL -Ol' Rusty
    93 GL - Lil Red
    91 L - Tweetystiva
      not sure about the bolt pattern of the Newer Festy's over there. I think they were changed to what we call the Aspire. If that is the case and they are the same as ours...then no they will not bolt up. As far as tires....I know guys here run 14" rims with 195/45/14's without any issues.
        yeah thats what i thought, wrong stud pattern, ok thanks for ur help
