ok, I am looking at my haynes manual now in the suspension part and the front strut and the orientation of the upper strut mount in relation to the body. It says to "mark the relationship of one of the upper mounting studs to the body. This will ensure that the strut mount is reinstalled in the same position, preserving the CAMBER adjustment"
In other words, when you turn the upper strut mount 180 degrees, you change camber...
now here's my question, when 180 degrees out from stock position, will this make it go NEGATIVE or POSITIVE camber from stock?
I just lowered my festy and have negative camber now....(tops of wheels closer than bottoms of wheels) and i have camber bolt to go in to compensate. but i want to know if i can turn the upper strut mounts to help.
