Festiva suspension replacement
  • Festiva suspension replacement
    Hello all,
    I'm looking to replace my rear shocks as mine are shot, and I'll be adding a lot of weight to the rear end come spring. I would idealy like to know if there's a spring from a different car that will pop in without any issues. I'd like it to be a lot stiffer and take a lot of weight. I believe the current springs are 3 7/8" outside diameter. Of ocurse if someone has other ideas, just shout 'em out.
    thanks.
    I think that the aspire ones will work just fine. But not sure how much weight they'll take.
    -Josh R
      I think pretty much anything othe than stock will be alright.
        Aspire springs are stiffer, but not much. Try a coil-over conversion. Then you can choose any spring rate you want.
